Do you have to torque the sway bar end links?
LS1Tech Premium Sponsor
^this. the most important thing is to make sure you tighten both side equally. it is easy to overtighten one side and induce some preload into one side of the bar and cause a weird "unsettled" feeling in the car
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
LS1TECH Sponsor
The spec only works on the GM bushings which are plastic. Urethane you cannot torque to spec, it will just deform. Snug is the answer.
__________________
With both sides of the car in the air replacing the sway bar bushings was extremely difficult. Hard to fit the top under bushing under the sway bar
Now that I think about this, I wonder if that is why my tires wear so hard on the outer edge, my lower control arms need to be adjusted outwards
When adjusting or mounting sway bar and related components, the suspension needs to be loaded.
Having the car on ramps is easiest. Either by driving it up on them or jacking it up and placing the ramps under the tires, then lowering it down
Then go to work on what you need to do
