Koni STR.T/Strano Spring
#41
LS1TECH Sponsor
Sadly many folks think, somehow that STR.T's are in some way equivalent to Sports, they aren't. STR.T's are built to fill a niche at the lower end of the market. And while their rebound damping is decent, it's not great and the durability is such that if they did not have a lifetime warranty that was well supported I'd likely not use them very often.
But they do have a warranty that is well supported. And I don't know that the valving is all that bad, but wonder if you have a shock that has failed on compression. Again, would recommend you swap left and right shocks and see if the issue changes sides or not.
But I will add this too. If you notice most complaints are the Right rear. The side where the exhaust crosses the Panhard bar brace, and that's a tight fit. And when the car gets stiffer, the exhaust in the soft rubber hangers tens to move around more since it's being jarred more than with softer stock springs. And when that exhaust bangs on the PHB brace, it can be a big thunk.
A little due diligence here would be helpful. Try the shock thing first and let's see what happens.
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
#42
Are yours yellow or orange?
The bumpstops, and the damping force in the shocks work hand in hand with the springs. Remember that my springs are some 40 pounds an inch stiffer than stock. We don't want them super stiff, lest you drive around in what seems like an empty one ton truck.
#47
for starters set the fronts at midway, don't know how many sweeps that is.
the rears +1 from full soft, you'll have a very responsive fun handling f-body.
or you can leave them at full soft and it will still be better than the bilsteins, but why go for better when you can have GREAT???
#49
I have the Strano/Koni STR*T combo on my 97 SS and let me tell you, it truly wakes up the 4th gen platform. I have no issue keeping up with more powerful cars around the curves thanks to the confidence inspiring grip that this combo provides.
