Rotots dont seem right
I was checking out the brakes on my 01 camaro ss and noticed my rotors dont seem correct. They are Powerstop drilled ad slotted rotors and holes are bigger then the studs, also not centered. Will this be ok or should i replace them?
Any car ive ever done rotors on rock back and forth a lil. Id guesstimate that the centrics i just did on my car had about 1/16 of an inch bigger diameter than the studs. Keep in mind after the wheel is torqued down, it dont matter the size of those holes, the rotor aint moving a bit
My OE rotors, as well as the Bendix replacements I later put on the car, had a little "clearance" around the lug studs, HOWEVER, the studs were centered in the holes, UNLIKE the one pictured.
To me, that rotor may be MOSTLY correct, from a diameter, thickness, centerbore, and offset standpoint, but I do NOT think the lug circle is correct. Note how the studs are contacting the outer edge of the holes, yet somewhat distant from the inner edge of the holes.
