Finally got my Strano break kit installed!
Finally got to spend the time this weekend to install my Strano Performance Parts front brake kit (http://www.stranoparts.com/partdetai...=7&PartID=1354) that's been sitting my garage since the end of November while I had a wheel ordering ordeal. My initial impressions are great. The car stops much smoother from higher speeds than before. Last night I was only able to get the bedding (break-in) process done but I will report again on how my driving impressions are.
Some words of advice....if you're trying to install new flex lines on a car with old brake lines, get yourself a little torch if you don't have one! Heat helps big time for helping 20 year old brake lines and wheel hub come apart! I got mine at Home Depot. Also, read the directions carefully! I was a dumb*** and broke a bolt because I misread a torque spec. Thankfully nothing was damaged and bolt was a cheap replacement.
Here's a simple write-up of how to install these brakes on a 4th gen.
Before picture from the other day when I just got the wheels...
by https://www.flickr.com/photos/156619454@N04/, on Flickr
Step 1 - Disassemble the brakes, pull the wheel hub off and cut the spindle as pictured. Before reassembling everything, make sure to clean the mounting surfaces....again, as pictured.
Step 2 - Put the UMI mounting bracket on (caliper faces towards rear), slip the rotor on, install the caliper and plumb up the new braided hose. Make sure to follow proper torque specs! After that's done, bleed the system.
After picture...
After picture...
LS1TECH Sponsor
This is the link he meant to post
http://www.stranoparts.com/partdetai...=269&ModelID=7
But yes, we use a UMI bracket with the Wilwood caliper. The kit includes brake lines, (not standard F-body lines), brake rotors, the bracket, and a set of Wilwood BP10 pads as well.
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
Sweet, thanks Sam!! I'll add it my growing list of wants.
LS1TECH Sponsor
For street and autocross I run EBD Yellowstuff, and I use Raybestos ST43 in them on the track. Both of which I generally have in ready stock.
__________________
I'm still undecided on which brake upgrade I'm going to go with. Car sees very light street and drag use. I'm loving the master cylinder brace btw! At some point, I'll be switching from Viking to the UMI/Afco setup. The color match to the UMI STB is dead on. I may powder coat my steering knuckles that color. Do you happen to know the red powder coating product and color used to paint these parts? Is it a custom or off the shelf formula?
LS1TECH Sponsor
Well it matches because they coat them for me which was on purpose because I know that folks are picky about things like that.. I really don't know officially what color it is, but I'm sure Ryan might be able to tell you. I suspect it isn't custom but can't swear to that.
__________________
