Does the 6 piston caliper bolt to the 4 position ??
Old 03-10-2018, 02:08 PM
BobH's Avatar
Default Does the 6 piston caliper bolt to the 4 position ??
Does the CTS V Brembo 6 piston caliper bolt to the 4 piston provisions without adapters a 4th gen F body ??
Thanks
Old 03-11-2018, 12:02 AM
taman86's Avatar
From what I have read, yes. The only difference being that the spindle bolt holes need to be drilled out to accept m14 bolts and also I've read that kore3 has different brake lines for each caliper; 4 piston and 6 piston, so you may need to look into that. Also the 6 piston calipers use 14.6" rotors, not 14". Look into replacement ctsv 2 or zl1 rotors
Old 03-11-2018, 06:33 AM
BobH's Avatar
Thanks.....Actually already have the rotors ,milled and ready.. Cart before horse !
Old 05-07-2021, 12:25 PM
MyCETA's Avatar
Hey you're in Houston too! Are you going to do this yourself or a shop?
Build update: Waiting on Big Brake Upgrade to respond to me with some parts I need.
Quick Reply: Does the 6 piston caliper bolt to the 4 position ??
