Squeal coming from rear wheel?
I have a 02 Camaro base model,i started getting this sight squeal from my rear end possibly the brake area but the brakes are just fine,could something potentially be rubbing somewhere? I does it often when I'm driving slow and when I'm on the freeway i can here it every now and then. Or could a bad wheel bearing be the culprit possibly?Any suggestions?
It slightly squeaks as I'm driving at a slower speed.and if I'm going fast and hit the breaks it squeaks right away and if i pull my foot off the brakes and re apply them it doesn't. I'm going to bring it in tomorrow.
you may need to grease or change your brake hardware. I always get squeaks at low speeds that go away when i re-grease the hardware but it always come back after a while. My grease choice probably sucks. Try changing and greasing all the hardware.
