Ss brake lines front only?
For the better or worse? I’ve read that our cars tend to have too much rear brake with the stock setup.
Not it sure if V calipers and SS lines will even it out or over correct the issue.
I just did the c7 Brembo upgrade on my car and only did stainless lines on the front for now. It stops okay but I didn't properly bleed the ABS block. Once I delete it I hope the brakes bleed out better and help the really spongy pedal feel.
Mine has never worked since I bought it 5 years ago. It works in here because you have to activate the abs while bleeding the calipers so instead of worrying about that I’ll just kill 2 birds with one stone and delete it.
I was told that you need to use a Tech 2 tool or find a way to have the abs activate while you are trying to bleed. IMO its a garbage system thats antiquated and full of issues. I would rather delete it and know that its never going to work again lol.
I like a gravel lot myself for that purpose haha, done it many a time. Tried to bleed the ABS on a few silverados and the scan tool says codes active, cant do. Scan all modules and there are no codes, hit a gravel lot, perfect brake pedal. Assuming you did a proper base bleed.
