14” brake rotar negative gains 14” gen 5 Camaro SS rotar weighs 24.6lbs Stock drilled and slotted rotar weighs 15.2lbs. Cts-V1 caliper weighs 7lbs. Thats over 9lbs of rotational mass. Wish I knew this before. Anyone considering taking on this project, hope this helps. https://cimg9.ibsrv.net/gimg/ls1tech...4ca327848.jpeg |
Not sure why you're surprised, It's a huge size increase size and with that comes weight. Unless you're going for looks or road racing there isn't much benefit to them. I built my s10 to be fast and handle well but my brakes are still overkill. You couldn't even see the stock S10 rotors behind the 18" wheels. Now I'm wanting to switch to more of a drag race setup so I'm going to be pulling them off so I can fit a smaller wheel. https://cimg1.ibsrv.net/gimg/ls1tech...0cd1ae84a6.jpg |
I didn’t do it for braking performance. My Infiniti has a bbk and the “braking feel” is a lot nicer. It’s also very nice to look at. I knew it would weigh more just not that much more. 9lbs is a lot and then I can only run 18” and up wheel so that adds even more weight. Perhaps a ATS upgrade would’ve been a better option. |
Originally Posted by 35thanni
(Post 19926857)
I didn’t do it for braking performance. My Infiniti has a bbk and the “braking feel” is a lot nicer. It’s also very nice to look at. I knew it would weigh more just not that much more. 9lbs is a lot and then I can only run 18” and up wheel so that adds even more weight. Perhaps a ATS upgrade would’ve been a better option. I didn't know drilled/slotted stock sized rotors were that much lighter. |
Yeah that’s a pretty big difference. I have a set of forgestar wheels on order. Those should help offset some of the weight gains. I’m sitting on c5 z06 reps now. They’re extremely heavy. |
Factory F-Body brakes will stop you just as well as the biggest baddest Brembo brakes made will stop you......Factory brakes lock the tires easy and will stop you when needed..........what more can you ask for. Now for track use, brake fading is what the issue is. Thats where upgraded brakes help. . |
Originally Posted by LS6427
(Post 19928000)
I used to do a lot of track days (HPDE) in fourthgen F-bodies. The stock rotors would last one day generally on a road course. 1 day. Stock calipers would spread an need replaced at least every year. I put Porsche 996tt Brembos on my car before I stopped doing track days. The rotors on it have 4 or 5 weekends, and 10 years of light street driving since. I am sure they will be on the car when I die. And the calipers will too. Brake pads also last longer as they aren't being overheated. That said, for anything other than full on road course use, the stock brakes are fine. The upgrades are mostly cosmetic. |
wouldn't you want a heavier rotor if you were trying to stop faster? heat dissipation and what not |
Up to the point of heat saturation, a heavier rotor is counter productive to stopping faster. Think of it as a flyhweel, resisting slowing down. Stock brakes are fine for a single stop, even from speeds above the stop speed limiter. I used stock pads stopping from 166 mph, no problems. |
im not arguing the integrity of the stock brake systems, but one of the reasons i always seen was overheated brakes are less efficient (not including full on race pads) and that less metal on a rotor (drilled is one example) won't be able to dissipate the heat as effectively since the metal is what absorbs the heat. less metal, less ability to absorb the heat created from stopping......thats why i figured a bigger rotor may be better to some extent. educate me please. and please no one turn this into a drilled or non drilled debate. |
^ i hear what your saying and believe more rotor= less heat, but i thought the whole point of cross drills was for heat dissipation. If not that then what are they for, purely aesthetics? And what damn pads are you'all using bc my stock brakes suck ass! My lil nissan altima sedan stops 10x better than my WS.6, thats why i want to do a 4pot cts-v brake swap and all you'all are saying it does nothing for braking performance really??? You didnt "significant" better braking after adding the 4pot brembos and 14" rotors? (I figured the extra surface area would help braking.) also what does the stock twin piston caliper weigh? |
Originally Posted by Snake_Skinner
(Post 19928157)
^ i hear what your saying and believe more rotor= less heat, but i thought the whole point of cross drills was for heat dissipation. If not that then what are they for, purely aesthetics? And what damn pads are you'all using bc my stock brakes suck ass! My lil nissan altima sedan stops 10x better than my WS.6, thats why i want to do a 4pot cts-v brake swap and all you'all are saying it does nothing for braking performance really??? You didnt "significant" better braking after adding the 4pot brembos and 14" rotors? (I figured the extra surface area would help braking.) also what does the stock twin piston caliper weigh? As far as your stock brakes sucking ass, Many times it's not the size of the brakes. It's a combination of rotor and pad material, Brake lines, Booster, Master cylinder and a proportioning valve. It's not uncommon to find that the stock booster/master combination doesn't give you the stop on a dime feel because they take more effort to get the same braking force than what you have experienced before. Personally I don't like brakes that you hardly have to press the pedal to feel like they are going to put you thru the windshield but I don't want to stab and pray either. Many years ago my Mom had a huge Chrysler New Yorker. The brakes were so touchy that you only had to lightly touch the pedal to stop. We lived at the top of a steep hill. I backed out of the driveway and start down the hill, About half way down I put my foot on the brake pedal and apparently who ever drove the car before me had adjusted the seat before they got out of the car and didn't get it locked into place. Lets just say as soon as I touched the brake the seat slid forward a few inches making me press even harder on the pedal. I literally locked up all four wheels for about 30', I hated that car lol |
I just posted the pictures as a reference for anyone looking into this setup. I don't understand the hatred for brake upgrades in the 4th gen community. Its not everyone, but for the most part every thread has a few replies ranting and raving about stock brakes. Generally speaking, its the same guy who refuses to spend $500 on a brake kit that has $5,000 into a HCI setup. I've driven cars with the bbk option from the factory and without and aftermarket add ons.. There is a significant difference even for daily driver use. |
I dont hate brake upgrades, ive just done enough of them to realize the benefits are nothing to write home about on a street car. With stock calipers & rotors, race pads & tires, a fourthgen will stop with the best of them. At least once. Like the OP, I discovered long ago there is a penalty for big brakes. Well a compromise. I'll cite my source. Lou Gigliotti explained to me long ago, in the paddock at Motorsport Ranch, that drilled rotors just reduce weight. Modern pads dont outgas in the duration of a single stop. And slotted rotors give the worn brake pad material a place to go when the car is being driven hard, like on a road course. I'm not here to argue. This is what I believe. Y'all are free to believe anything you like. But I encourage you to cite your experience and sources so others can make an educate decision. EDIT: FWIW I was one of the early adopters of big brakes on fourthgens. I had the fifth set or so of the LG G-Stop brakes, and had these by 2004: http://oi29.tinypic.com/2e55dnq.jpg They are still on my car. |
I guess what it comes down to is if u can get ur ab's to activate or ue wheels to lock in a non abs vehicle than the only benefits are from pedal feel..... I'm talking about a street car here not a dedicated race |
(Post 19928157)
© 2024 MH Sub I, LLC dba Internet Brands
