PSA about power steering pumps, turn one power steering pump rebuild?
i recently decided to send my pump and rack to turn one and i think anyone who hasn't yet replaced their pump could benefit from this next paragraph. they received my rack an did the rebuild, no issues, it passed their dyno, i haven't yet installed it. however after the did the high performance rebuild on my pump, they call me to tell me my pump failed the dyno inspection. i was upset at first because i thought i would have to still pay for the rebuild of a bad pump, but they actually dont charge you if the pump doesnt pass. anyway, whats important here is why it didn't pass, inside the pump where it rotates in the bore, the bore wears out from the metal on metal contact. so after they rebuilt and tested, due to this wear i had fluid pressure loss. whats interesting is i had absolutely no issues when i pulled the pump, but this could be because of the higher pressures the stock pump operates at. no idea how much pressure is inside the pump, but to better explain this, say my pump was pumping 75 psi, but was leaking past and was now doing 50 psi, thats still enough to power the rack pretty easily. but the high performance rebuild does a few things that operate the pump at less pressure. so say there pump pumps 50 psi, but now with the leak its doing at the same 33% at 34psi operating pressure, thats a huge difference now and will most likely be felt with increased steering effort, which will only continue to get worse. so how does this affect you? well that reman pump you wanna by buy because you dont need anything special is goona be a used housing, which most likely will have some wear as well, especially if they dont dyno test the reman for pressure loss after the rebuild. you in theory are most likely buying a pump that still will be losing some pressure due to the housing wear.....bottom line, if you ever consider replacing the pump, i would highly recommend getting a new pump.
no issues with my steering besides a slightly damp rack, but my motor is out of the car so lets replace this 19 year old rack. ive seen turn one has had basically no bad reviews on this site, so they will be getting mine for a rebuild. that leaves me to the pump. i figure we mine as well replace that now as well since the rack is already disconnected. i contact them as well about pump rebuilds, and this is what a sales rep said....
For the pump, we offer a standard rebuild and an upgraded rebuild for high performance use. The standard rebuild starts at $150, the upgraded rebuild starts at $200. The upgraded rebuild upgrades the pump to reduce horsepower consumption, reduce fluid temperature, and also increases the pressure capacity of the pump to handle higher wheel loads that high performance driving produces. In addition to our rebuilding services, we also offer 100% new (not reman or off-shore) high performance power steering pumps that are track ready. The new pumps are $325.
does the upgraded rebuild sound worth it? is it a decent idea to address this old pump or just let it go?
Save the manuals!
The post above is the first one I've seen here about problems with a TurnOne product. They did a stock rebuild on my pump and the work is spotless.
I expect that they (unlike some other options) will stand by their work. I recommend TurnOne's upgraded pulley, regardless of which option you go with. The pulley is permanently attached, but the pump bolt's up to the block in a snap and you no longer need to deal with a remover.
There's no such thing as a free lunch. (You have to give something to get something.) In City driving, the upgraded pump should have a higher steering effort to it. So, if you are just using this as a daily driver, you'd probably be best with a standard pump and wouldn't see a pay-off from the upgraded features.
We run Turn One pumps on every UMI car. Usually at 7000+ RPM and with sticky 315 tires and a lot of steering. Never had a single problem, ever. Two leakers is an anomaly.
The high performance rebuild is totally worth it. On our '99 SS we had overheating trouble prior to the Turn One. A big cooler helped a little but we still burnt pumps every few races. After the Turn One, we were able to take the cooler off.
ramey
ramey
The following users liked this post:
1SS2NV00 (12-29-2020)
I use my cars daily. They didn't hold up. Stock pump lasted over 10 years on Camaro. Over 20 years in the Vette. Swapped to a Rock auto A.C. Delco on Camaro and it's been fine for last few years so far. I bought the optional pulley on my Camaro Turn 1 and it makes changing it a breeze. Steering effort was barely worse.
After all the raving about Comp Trinions,Viking coil overs two other mistakes I did to the car I don't read posts from any vendors anymore
im with you morris about listening to vendors, however umi honestly hasn't steered anybody wrong that im aware of. and they dont sell turn one pumps. i also bought vikings lol, hence my long thread from awhile back. i might gamble on the turn one pump rebuild, only because a "new" gm pump that has been on the shelf for under 1 year just isn't goona happen, and they will be doing my rack regardless. i do appreciate the info tho, it just seems like the options are "who the hell knows" branded rebuilds, or a turn one. at least i will know who rebuild mine, not what the label says.
Save the manuals!
Let's get back to power steering pumps...
We have lots of members here who have had great and long experiences with Turn One Pumps and yours is the first bad experience I've seen.
Can you tell us more about your situation? Did they leak out of the box? If so, did you ask TurnOne to fix them? Where did the cores come from? (Were they known to you and good before you sent them off?)
Save the manuals!
http://polymerdatabase.com/polymer%2...lastomers.html
Save the manuals!
