FOUND - Stock Fourth Gen LCA ABS Sensor Retainer
I've been searching for this part forever, so I thought I would share the event that anyone needs/wants one.
The stock Lower Control Arms on the Fourth Gen F-Bodies have an odd stacked conduit clip, which holds the front ABS lead as a stand-off. I broke one and have been searching for the replacement for a long time:
I was able to find some new old stock for the part, which is a Stacked, Arrowhead Conduit Clip for a 6mm conduit over a 9 mm conduit. Part number 12045796. (The part was made by Packard Electric Division, which became Delphi, which sold to Aptiv. Aptiv now has the part number.)
It looks like these things are discontinued, although Aptiv may still put them out for people in a special run with a 1000 part minimum.
The following 3 users liked this post by wssix99:
Theoretically one could. Aptiv used to post measured drawings for all these parts, but they are harder to download recently. It looks like the conduits have spun off again to yet another company, HellermannTyton. HellermannTyton doesn't seem too interested in posting information or specs about these parts...
It looks like Aptiv is in the process of gradually shedding part numbers off to HellermannTyton vs. dumping everything all at once.
If anyone knows of a vendor who would take the stock of me and offer it to the community, please let me know! (At this point, I have what I need and would rather pass on the remaning 45 clips so they are out of my shop.)
Do you still have some of these abs stand off clips, I’ve been searching for them awhile now, and ran across this page. If you do any way I could purchase 4 of you. Thanks
Clips
Bummer, guess I’ll start searching for just another GM clip that will work, a zip tie works but like something a bit more better looking. Thanks for replying back.
Its going to be another week before I track these down...
If you look at the picture, the part is just a #6 retainer stacked on top of a #9 retainer. You can still get a "Delphi #6 Rosebud Clip" and it will hold the conduit just the same - it just won't have the stand-off from the LCA.
Clips
Here's one that's in-stock and should fit. https://www.mouser.com/ProductDetail...jeJ68E9Q%3D%3D
Clips and Fastners also sells it: https://www.clipsandfasteners.com/GM...D-p/a19795.htm
