Can't get the caliper back on
Old Sep 16, 2004 | 04:32 PM
SamB's Avatar
Default Can't get the caliper back on
Need some help with getting the caliper over the rotor/pads. They came off fine but do not want to go back on, when I took them off I had the emergency brake set if that matters. Is there a way to expand the cups inside the caliper? I have a 98 Camaro. All comments will be appreciated. Thanks.
Old Sep 16, 2004 | 05:23 PM
Camaro01SS4life's Avatar
You have to compress the piston back into its seat...The easiest way to do this is to:
1. Take the brake resivior cap off
2. Find a metal plate that will stretch across the two pistons on the inside of the caliper
3. Get a clamp, then start clamping the plate which is over the pistons till the pistons are seated...This should give u enough clearance to slip the caliper back over...
Hope this helps...
Kevin
Old Sep 16, 2004 | 08:19 PM
VIP1's Avatar
Copy & Paste Moderator
Just to add to it....
2. ...the old brake pad is good for this
3. ... just to clarify... big metal C-Clamp
Old Sep 16, 2004 | 11:33 PM
2002 Trans Am's Avatar
hmmm, take the resevoir cap off.....Brake fluid should come out if I were to do this correct?
Could I do this without removing the resevoir cap, I was always under the impression that you just push the piston back with the c-clamp and either a piece of wood or old pad
Old Sep 17, 2004 | 12:18 AM
zombie1's Avatar
Just remember if you do remove the master cylinder cap have a rag of something over it, brake fluid WILL spray out of the master cylinder and all over your paint and everything else, GO VERY SLOW!!!!
Old Sep 17, 2004 | 07:48 AM
Fulton 1's Avatar
Yes, you'll have to remove the cap when you compress the pistons. Just take a shop rag (as noted above) and lay it over/around the master while its open. C-clamp + wood or C-clamp + old pad works well to compress.
Old Sep 17, 2004 | 03:21 PM
SamB's Avatar
Thanks for the help, job completed.
By Brett Foote | 2026-06-04 05:00:17
