LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Suspension & Brakes (https://ls1tech.com/forums/suspension-brakes-16/)
-   -   Torque Arms and LT's (https://ls1tech.com/forums/suspension-brakes/228397-torque-arms-lts.html)
99'Formula Oct 17, 2004 04:45 PM
Will any torque arms work w/ LTs and y-pipe. Because I saw that spohn sells one for LT's and y-pipe. Also what would you guys recommend for a torque arm. I decided to stop buying power mods becuase 1st gear is useless. No point in having power if you cant apply it to the ground.
Thanks
Mark98SS Oct 17, 2004 05:18 PM
Spohn's TA will work with any combo of LTs, Y & catback. It has a nice big area on the right side for the exhaust plumbing to go thru. I have two 2-1/2 in pipes snaked around it no problem.
99'Formula Oct 17, 2004 05:25 PM
But will any Torque Arm work w/ LT's and y-pipe?
DARK AGE 53 Oct 17, 2004 08:06 PM
Last year we installed an Edelbrock torque arm on my friends SS, this year ( more power ) he wanted to go with the Spohn so we installed it, no problems with the install and he also has SLP LT's.
Al
01SLPSS Oct 17, 2004 10:48 PM
Get the Spohn T/A with the dropped crossmember for y-pipe/LT Clearence. That's what I have got on my car.
99'Formula Oct 17, 2004 11:49 PM
I guess Spohn is the way to go.
DanZ28 Oct 18, 2004 01:27 PM
I think most TA's that mount in the stock location will clear LT's and Y. I just read a thread about the Spohn TA made for LT's has scraping issues on "non-lowered" cars though...
Dan
99'Formula Oct 18, 2004 10:33 PM
Dan
Yeah I have also read that. Also I work at a speedshop and we guted a car today and it had huge dents in the center hump in between the rear seats where the TA smashes against the floor (From a Spohn Adj. TA). Anyone else have any problems like that? Or from any other TA?
LeddySS98 Oct 18, 2004 11:43 PM
I have Spohns TA, and Kooks LT's with 2.5" TD's...
Ground clearance has become a bit of a problem is my only complaint...
https://ls1tech.com/forums/generation-iii-external-engine/224506-i-got-my-td-s.html
© 2026 MH Sub I, LLC dba Internet Brands
