how do you install a rack and pinon on a Z28?
Old 11-26-2004, 07:19 PM
LS1TechRulez's Avatar
Default how do you install a rack and pinon on a Z28?
I've searched all the boards for some sort or walk through or writeup and found nada. since this is such an important part of the car I want to be sure 100% that I am doing it right! any links or help would be great! thx!
btw this is on a 2000 z28
Old 11-29-2004, 11:20 AM
technical's Avatar
It's not that hard to replace.
Couple of hard lines, two mounts, steering shaft, tie rods.
Lock the steering wheel so that it does not spin while the shaft is disconnected, that while break you SRS slip ring and your airbag won't deploy.
You'll definitely want to get an alignment afterwards.
