rotor wont come off...
ok, i saw that my rotors had crackes in them and i am putting some stock ones on so i can send the cross drilled/slotted ones back to the company i bought them from so they can send me some new ones for free (good cumstomer service). but the drivers side rotor will not come off for the life of me, i tried everything imaginable and cant get it removed. the passenger side slid right off like it is supposed to so i cant understand why the drivers side wont come off. any help or advice is appreciated. if i cant get it off im just gonna raise the car and slam the back of the rotor with a hammer until it comes off. thanks in advance.
Kyle
Kyle
if you are worried about damaging the rotor put a piece of wood in the opening for the caliper on the back of the rotor an wack it with a hammer, turn the rotor a 1/4 turn and repeat till it breaks loose
Copy & Paste Moderator
Check out this thread for some info on how some people have gotten their rotors off. I also have some pics there of what my rotors looked like after they were removed (on page 2).
https://ls1tech.com/forums/showthrea...ighlight=rotor
14 Second Truck Club
Spray the center with some nut buster and let it sit. Then heat the hub area near the studs. It should come off with a dead blow hammer or heavy rubber mallett then. That is usually how I do it. If I will not be reusing the rotor I use a 3 lb sledge.
Buy some "Liquid Wrench" and a rubber mallet....Works incredible
I spent a lot of time with a hammer and PB Blaster and nothing, then I broke out the Liquid Wrench and had it off in less than 5 minutes
