LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Suspension & Brakes (https://ls1tech.com/forums/suspension-brakes-16/)
-   -   Sphon LCA's PROBLEM (https://ls1tech.com/forums/suspension-brakes/247718-sphon-lcas-problem.html)
SpankysWS6 Dec 8, 2004 11:19 PM
Sphon LCA's PROBLEM
I have a 2000 WS6 M6.. Problem since changing out the factory LCA with Spohn LCA's.. When Driving down the Highway the Rear of the car feels like I have a bad Passanger Rear shock.. Swapped the Passanger and Driver shock and same results.. Tried loosening the LCA's and still the same.. When I had the Factory LCA's I didnt feel this problem.. Other thing I notice is running on the highway at 70mph.. I will push down on the accel and the car pushes itself over to the left.. if I let off it goes back to normal.. Like rear end is twisting..
Only thing that I can think of is the Weld in Subframes are not installed correctly..
Any advice and Ideas would be great.. Any local shops around Burleson and Fort Worth and Dallas area would be great that wont break the bank that I could take it to see what is the problem.. :bang:
mitchntx Dec 9, 2004 06:04 AM
Are the LCAs the same length?
SpankysWS6 Dec 9, 2004 08:20 AM
[QUOTE=mitchntx]Are the LCAs the same length?[/QUOTE
I will check that.. It is driving me crazy :eek2: Anyone ever have this proplem? Thanks for the info
MeentSS02 Dec 9, 2004 12:04 PM
Are these the poly/poly LCAs or rod ended?
SpankysWS6 Dec 9, 2004 08:21 PM
They are the Poly Poly
DARK AGE 53 Dec 9, 2004 09:30 PM
Originally Posted by SpankysWS6
Problem since changing out the factory LCA with Spohn LCA's.Like rear end is twisting..
Did you install the LCA's and SFC's at the same time, also have you checked to see if there's any problem with the TA?
© 2026 MH Sub I, LLC dba Internet Brands
