rear ride height adjustment?
Does anyone out there make adjustable ride height inserts for the rear springs on an F body? I've seen them, just cant find them. I installed a pro-kit and the back of the car sits too low. Believe it or not I have plunger ends inserted in the top of the isolators now and it's perfect but it's kinda a hokie way to get the height I want.
Ground Control makes rear adjusters. You'll need a shorter spring though.
http://www.ground-control.com/?D=72f...7607aca9045a31
Cutting Board Spacer
I have the Ground Control kit, but you have to buy their spring as well.
I remember seeing a guy cut some spacers out of a couple plastic cutting boards. You can put the spacer in between the spring isolator and the body and that would be better than adding extra flex into the spring path.
Ok. I meant you should have springs that are much shorter that stock because those adjusters start off about 1/2" or so higher than the stock spring perch. That''s because they sit on top of the stock spring perch then you can raise the rear about 2 1/2" inches from there. You could also remove the spring isolator to lower it 3/4" more and get into the sweet spot.
I suppose if all you wanted to do was raise 1/2" then it would work and now you can balance the ride height. The cutting board spacer is much cheaper if money's a concern.
And that 'sitting on top of the spring perch' is a hokie setup too IMO. I wish I'd have seen this earlier, I'd have given you my GC spring jacks. I took mine off & inserted some 4" dia Mr Gasket spring isolaters on the 2nd coil from the top. Now my car sits where I want it with 315s & actually rides better too. I always worried about taking a hard corner under power & having one of the GC jacks pop out! There are a lot of smart guys like Strano that have used them, but I don't like the design. Now if you cut the nipple off the perch & welded them on....
ssPetess you could always replace the upper isolator with heater hose. This will give you about another 1/2" of play and still have the sound dampening. I would try to stay away from cutting the spring as much as possible
Originally Posted by The Golden One
So would this kit help on an Eibach Pro kit because I also have one side sitting lower than the other....
