abs not working
abs not working
Some of you read about my issue with my ABS unit a little while back. Anyways, I finally got around to replacing the ABS unit. Install took 15 minutes and the linelock works fine. Everything seems fine.
I bled the brakes la la la. Pedal pressure is good. Car stops good. ABS INOP light is on and the ABS is not working (trust me ).
What do I have to do to jump start this unit into working?
are you certain your new abs unit is working correctly, is it used or new. Check fuses, check connections that's an easy check. The abs unit may need to be checked with a tech 2 tool to verify cycling and/or abs computer codes.
I'd say just remove it and replace it with a proportioning valve. ABS can be just one more thing to troubleshoot and have to deal with.
