Suspension For My Needs
Right now all I have are BMR SFC's and STB, and a Tunnel Brace. The front of my car is 6 inches from the ground due to the front gfx, and the tunnel brace is around 4 inches off the ground at the transmission. This car will probably never see the track, but I would like to do some suspension work, lowering a little if possible, for daily driving just to make the ride a little more enjoyable. What would you all suggest? My ground clearance has me worried on shocks/springs b/c I still want to be able to drive the car. I have thought about getting some LCA's also...
well, since your G/x kit is built to hang low......its not urethane is it? Anyways, Instead of lowering the car, which would help but be bad because f your kit hang so low, why not opt for a set of solid swaybars. This will help in makng the car more enjoyeable to drive. The car will go where you point it...
Sam Strano sells a set of 35/25mm bars. Also others sell a 32/21 package that will help in the fun department. Also, a torque arm will help in transmitting more of the power to the wheels which is good.........
But try to stay away from the LCA for now. You really dont need a set..if anything, get a set of 1LE with the hardened rubber bushings. Also, a tubular PHB will be a good idea since i will make the movement in the rear less noticeable....
if you must lower it, Sam Strano or ground control sells a coilover kit with ride adjust on the four corners.....That should help to dial in your desired ride height..
