Still Having Brake Issues HELP!!!!!!!!
Well guys id like to really know what would cause the wheel to vibrate alot from high speeds that and well i have the whole pedal pulse thing yet i never really seen a warped rotor to know what it would look like so if anyone can help me with these issues id appreciate it . thanx
there is no visual evidence you can see with the naked eye when a rotor is warped. only way you can see something visual is hook up a dial indicator and measure for runout.
theres a about a 99.9% chance that if your pulsating/vibrating when you applied the brakes, your rotors are warped. warped rotors is about as common as an oil change on f-bodies.
if your also getting a vibration while driving highway speeds than you may also have a bad tire or a tire that may simply be out of balance.
when replaceing rotors, stay away from the cheapies cause your gnna run intot he same concern after a short time.
hope this helps...goodluck.
I dont get vibration during high way speeds i get vibration while braking from high speeds like getting off the freeway i have a led foot so i usually do 100+ on the freeway so then when say i get on the off ramp and start braking the wheel vibrates what might be the cause ?
common guys plz someone has to know this .. im sure.. plus im close to getting my tax return and i want to see if i can get a ram air hood or if i have to do a brake job.
I had the same thing on my 2001 last year. High speeds stops were murder. I almost bought new rotors. I removed the tires and checked the brakes. Everything looked OK. I torqued the lug nuts to 100 lbs and have not had a problem since. I always make sure all wheels are torqued to 100 lbs especially after having them rotated or balanced. Most places say they torque them but do not do a good job of it.
Bill
Bill
