Can't reinstall factory LCA
Has anyone ever had a problem putting in the front bolt for an LCA? I'm in the middle of installing my SLP SFCs and thats the last thing thats keeping me from getting the driver side done. The LCA hole will not line up w/ the hole in the chassis. Is there something I can loosen to give me that extra 1/8" or so, to get the bolt holes to line up?
FWIW, it took me an hour to figure this out when I installed my SLP SFC's!
EDIT - this is assuming you start w/ the front-bolt (like trackbird suggested)
Good luck!
-Andy
DONE! I had to jack the rear end off the ramps and mess with it, but the holes finally lined up. As for the lip on the chassis, I used the BFH mod to get it to the point where it would bolt up nicely. I didn't have a grinder/dremel on hand, so 2 of the middle (trans tunnel brace) bolts didn't get put in, but I figure since the car has SFCs, those 2 bolts shouldn't make too much of a difference.
