Suspension Techniques Front Anti-Sway Bar Question
I got this Suspension Techniques Front Anti-Sway Bar from summintracing and just figures its too big to assemble. Who has assembled one I really need help, about to freakin out
Yep, it's heavy but it installs the same way. It's a fairly easy remove and replace thing. If it's the 35mm solid,,, you will like it. Just don't run the 25mm rear that they have to go with the 35mm rear. It's too large for most people under most circumstances.
Same question as trackbird. Same 35mm ST bar and it installed fine. I think I had to cut the hole for the bar a bit bigger and I think I chucked a splash shield but it is on there and made a noticible difference.
Brian
Brian
