Can't get rid of the squeaking
Old Apr 14, 2005 | 09:07 PM
shouldaboughttheZ's Avatar
Default Can't get rid of the squeaking
I just changed the back rotors to the IRotors cross drilled and slotted set up. I used O'Reilly brake pads. I cleaned everything, and greased the pins in the bracket and the pins that the pads sit on. I still get that damn squeaking while stopping. It does it as I start to brake (normaly) and quites when I push the peddle down harder. I am at my whits end here.
Any suggestions?
Old Apr 17, 2005 | 07:59 PM
00PewterSS's Avatar
Are they anti-squeal pads? with the teflon covered thing on the back of the pad where they contact the piston and the caliper? If not did you put that anti-squeal stuff on the pad, it is in a tub and dries rubbery like silicone or something. The squealing usually comes from the piston to brake pad, but can come from the pad to rotor.
brian
Old Apr 17, 2005 | 08:02 PM
I bought the pads from O'Reilly ahey gave me organic pads orginally. They should have given me ceramic. Got it straightened out yesterday. I ended up with Wagner brakes now. They are supposed to have some sort of Thermal Anti squeal on them. I put them on last night and have not had any squeal.
