QA1 shocks/springs How low in the front??
Im going to get a set of qa1 shocks and springs for the front of my car to match the qa1's in the back. I know the qa1's are ride height adjustable and was wondering how low can you make the fronts before you have problems. I was looking to lower the fronts 1"-2" and was wondering if it could be done with these shocks without problems.. What spring would i need, i see that the 275 is basically stock/drag racing spring and the 325lb ones are more for the street handling. Would i need the bigger springs if i wanted to lower it to keep it from bottoming out... thanx.
what did you guys use for rear springs?? i plan on doing Qa1's all around and i want to lower the car also, so i know the front can be lowered with the Qa1 deal, but can i just use any kind of spring i want for the rear to lower it?
https://ls1tech.com/forums/suspension-brakes/306061-qa1-rear-coilovers.html
