Regroove F shocks to lower car ?
Restricted User
anyone ever try this? I was thinking of doing this
on a lathe at work. I was going to add groove 1''
down & same depth as factory groove. I know this
is a gas shock and has high pressure inside.
Thanks
pic..http://www.slponline.com/cad2004/cad..._5.asp?PIC=120
Thanks
Thanks
Thanks
I would probably get a spare shock, and drill the bottom to vent the pressure, then cut it where you plan to groove the other one. If it is the same wall thickness, you may decide to go ahead with your plan (your call), but I'd be nervous just cutting on a pressurized shock (without researching another one by cutting it up). I'm not sure I like the idea, but if I were going to do it, that's how I'd probably go about it.
Or, I should say:
"Leave all shock modifications to properly trained technicians, shocks are dangerous, etc".
Or, I should say:
The dirt track guys do it all the time. It's a common practice.
But that is with AFCO or Carrera shocks. Not sure if Bilsteins, Konis or DeCarbons have a uniform wall thickness.
So, like Kevin suggests, experiement on a another shock to see how much wall thickness there is ...
Originally Posted by Blk02Z
I'd be afraid of cutting open a shock.. but thats me.
If we don't hear from you again, I guess we know the results
Restricted User
Thanks for reples, i had old decarbon shock to test,
1st drilled .06 hole to vent pressure,worked good.
Used lathe to cut apart. The tube wall is .080 thick
The groove is .030 deep, so i am going to try this
on my good shocks.
on my good shocks.
Good luck, sounds promising. Of course, it's still a decarbon and you may not have exactly what you need for damping at that height. However, the decarbons have "lots" of compression damping, so you might be ok. I can't promise how it will ride though. Keep us posted.
Restricted User
Well, I finshed install,went for 1-2 mile test drive
and car is now 5/8 to 11/16 lower. I moved groove
7/8 and hoped car would go 7/8 to 1''. Time for
new alinement & more driving.
