Suspension Compatability Questions
Right now I have the Bilstein HDs and Sprint springs (2" drop) and the car rides like shiet!!! I ordered a pair of eibach pro-kit springs (1.1" drop) should the ride in my car be a lot better than it was before or worse??? I see that slp sells the eibachs and bilstein combo so I figured it should ride smoothly. The only major problem i have now is the car absolutely bangs really hard when going over a bump.
Thanks Guys
Thanks Guys
If the car's banging really hard, it sounds like you aren't running enough rate for that drop to control the car's height. Do you know your current spring rates?
