subframe connectors...just got a set...
just got a set of BMR tubular subframe connectors for my birthday.....my friend derek knows how to weld so we were just going to do the install ourselves and save money. Any intstructions or directions available? tips?
thanks for any help
thanks for any help
thanks for any help
thanks for any help
I am assuming that this is basically how i need to do the install......
Remove front LCA bolt and let it hang, position the sfc on the LCA bracket and make a tack to hold it then lay a good bead around where the sfc contacts the sub frame and bracket... and then since the front of the sfc cannot move, just lay a good bead around it to attach the front sub frame.... then as previously stated, torque the control arm bolts to 90 ft/lbs.... there any stuff ive left out or is that basically it? semms like a pretty cut and dry install... thanks
Originally Posted by Nova5
with the suspension loaded? why?
Plus its easier when just the wheels are on a lift rather than having the lift holding the car at the jack points, which are near where you will be welding..
Originally Posted by Brandon
that way the car doesn't 'sag'
