Frozen rotors
Frozen rotors
http://www.tirerack.com/brakes/brake...ors&perfCode=P
Has anyone tried out these rotors? Are they any good?
http://www.tirerack.com/brakes/tech/....jsp?techid=83
Frozen Brake Rotors: Cryogenics 101
Deep cryogenic treating is a one-time, homogenous process that permanently and dramatically improves the performance and useful life of metals in everything from brake rotors and performance engines to machine tools and gun barrels. Using a proprietary computer-controlled process, the metal is cooled slowly to deep cryogenic temperatures (-300°F), and slowly returned to room temperature, then heat-tempered as the final step. Computer technology allows the regulation of temperatures to 1 degree, accurately manipulating the Cryo treatment in accordance with the mass of the part it is being applied to.
Although not apparent to the naked eye, the improvements to the metal are significant. Deep cryogenic processing creates dramatic increases in abrasive wear resistance and durability. The increases in tensile strength, toughness and stability couple with the release of internal residual stresses.
How the Process Works
Deep cryogenic processing permanently refines the grain structure of metals at the atomic level. This creates metallurgically improved and stabilized rotors that have a more dense, smoother structure. As a result, you reduce heat and wear on brake rotors and pads.
Applications of Cryogenic Processing
Brake rotors, performance engines, transmissions, gun barrels, cutting and machine tools, stabilizing ferrous and non-ferrous metals.
Well I'm not sure about brake rotors, but i had one of my rc nitro engines cryo-frozen.. On a regualer motor i was only getting about 3 gallons through them(about 3months of competitive racing) before i had to rebuild it.. Now I'm on my 5th gallon with the motor I had frozen & have yet to rebuild it, still has a ton of compression & running strong.. Not to mention the process is inexpensive to have done.
-Mike
-Mike
-Mike
-Mike
Originally Posted by Andros
So someone like me here has to test these puppies out huh? How many miles do the brembo oem last?
http://www.superchargersonline.com/content.asp?ID=98
Did you really have to shut me down like that
I'll be getting the brembos than
While there are great achievements in materials science and engineering, one must note that even though these brake rotors initially have a much stronger molecular bond due to the lower temp forcing them to have much less molecular movement, brakes can and will generate much higher temperatures, thus redistribute the molecules in a fashion similar to brakes that weren't cryoed.
If I can find the website, I'd like to post it here, because the person with drilled rotors was tired of all of the stress risers, so he cryoed them. After the same duty cycle, the stress risers revealed nearly the same characteristics as the non-cryoed ones (the drilled rotors at least came in handy for this purpose). He even had them analysed though an electron microscope and there was no difference at all.
