Camber settings for stock ride height.
Old 08-26-2005, 06:27 PM
kidkl's Avatar
Default Camber settings for stock ride height.
Hello,
I have what I am 99% sure is a camber problem. In ~3500 miles I wore the outer edge of the front tires from ~70% to ~10% . Got some new tires and got an alignment But they say that there was "nothing wrong".
Left Front:
Caster: +5.36
Camber: +.32
Toe: 0
Right Front:
Caster:+6.36
Camber: +.68
toe: 0
Based upon some other posts people said that that they have zero tire wear issues with:
Caster: +5 +5
Camber: -.7 -.7
toe: 0 0
Do you guys think that this should solve my camber problem?
Old 08-26-2005, 06:49 PM
pimpmaro's Avatar
negative camber helps with cornering. if you have a problem with wear on the outside of your tire and you engage in "spirited driving" I'm sure that having positive camber is a contributing factor to your problem.
Old 08-26-2005, 06:57 PM
kidkl's Avatar
Yea see thats the problem I don't engage is spirted driving but maybee once a month.
Old 08-26-2005, 11:03 PM
pimpmaro's Avatar
What tire pressure do you run? Do you take turns fast?
Old 08-27-2005, 01:56 AM
kidkl's Avatar
Been running 32psi... Taking turns at normal speed.. to be honest for the most part I baby the car. Any sort of agressive driving is mainly done in a straight line.
Old 08-27-2005, 03:45 PM
99PontTA's Avatar
reduce the camber + .10-.25max
Quick Reply: Camber settings for stock ride height.
