BMR drive shaft safety loop and bar
Just had the BMR driveshft loop installed today. BMR sfc and strut tower brace have been on the car for months. As soon as I backed the car out of the shop, I got this vibration or rubbing motion you can feel coming up thru the chassis. We (me and shop owner) looked under the car and we had plenty of clearence between the driveshaft and the loop. I agreed to leave the loop on for the time being, but its pretty irritating. Prior to putting this on, the car never squeaked or rattled, even before the sfc were put on it. Could this be a noise, vibration issue caused by the extra rigid, BMR safety loop? Maybe the weaker factory brace absorbed some of the extra vibration and cancelled it out? We disconneted the back of the driveshaft to slide the loop over it and into place; could the driveshaft be out of balance from the re-tighten of the shaft? The vibartion thing is kinda similar to what you feel when you put poly bushing on a car, instead of the factory rubber. Any body else experience this issue? Any suggestions would be appreciated. Thanks
Take a look at the pics in my sig. The BMR loop can be seen in one of the photos. Does this look like yours. I had no problems with the install. Check the actual driveshaft to be sure they installed in correct. Maybe a balance weight or something was damaged when they dropped it for the loop install?
LS1Tech Premium Sponsor
Sound like the driveshaft is rubbing against the loop. Just double check it for rub marks. If you still have problem give me a call on Monday or email me and i'll try to help you diagnose the problem
Lee Spicher
lee@bmrfabrication.com
(813)986-9302
Lee Spicher
(813)986-9302
Lee Spicher
(813)986-9302
Lee Spicher
(813)986-9302
