WDP Still squeaking
WDP Still squeaking
Purchased Wholesale Direct Parts, Crpssdrilled and slotted rotors w/ zinc coating and there Metal Masters Axxis pads.
beem on the car for a good 2,000 and they still squeak typically under lighter pressure but they SQUEAK LOUDLY! Why is this i don't understand, Calipers Rebuilt and everything they just keep squeaking
Everything is in perfect condition...i all new parts...I dont get it I eman yeah the pads are mostly metal, and the metal-metal sound is normal i feel, but still light braking just Squeals!
I can't really tell, i am gonna say front because its under light pressure braking more so then anything else. Under quick stopping or more applied pressure its fine
I have the same problem on my Durango with the drilled and slotted zinc plated. But I used Hawk's ceramic/metallic blend pads. I put the exact same setup on my TA and I don't have any problems. Things to try.... put disk quiet or some sort of anti-squealing compound on the back of all your brake shoes and make sure your slider pins a throughly greased. My first brake job on the TA caused squealing for about 15,000 miles and had no time to fix it.
