View Poll Results: Non-lowered car owners with adj. lca brackets@lowest hole: have you gotten brake-hop?
Voters: 3. You may not vote on this poll
I'm not lowering my car, but I do know that adjustable lower control arm brackets will still help me get a .1 or better reduction in 60 foot times (from UMI's description). I'm concerned about brake hop. I did use the SEARCH function and read about cars, at the lowest hole, getting brake-hop. However, those cars were LOWERED. So, I'm conducting this pole to see if anybody with a non-lowered car actually got brake-hop with the brackets at the lowest hole. Please vote above. Thanks in advance.
Originally Posted by CW00BlackTA
Don't know about brake hop but he car didn't handle well at all while cornering.
In theory with the arms lower in the rear and higher in the front, under acceleration it will plant the tires by pushing down on the rear axle and lifting the car. The flip side is that under braking it will want to lift the rear axle and pull the rear of the car down. That would make the rear light under heavy braking which might contribute to brake hop.
Altering the LCA angles can also effect the handling while cornering, but I can't remember the specifics.
Lowering the LCA’s increases anti-squat. Many drag racers will lower them as low as possible. The downside to this is lowering the LCA’s will cause roll oversteer which will make the car hard to control on course and can be very dangerous. It’s preferred to keep the LCA’s as close as level to minimize the amount of roll steer. In fact it’s preferable to have them slightly inclined towards the front to provide roll understeer which helps in applying power on corner exit.
Roll steer in the rear suspension is caused by the fact that the rear LCA’s scribe an arc as they move. When the car rolls in a turn one side will squat and the other lift causing the LCA’s to move in opposite directions-which they do and in an arc. The effective length of the LCA’s being longer on one side and shorter on another points the axle in a direction non-parallel to the car. If they rear axle points out you get oversteer and if it points in you get understeer. Roll steer is unavoidable but can be minimized by keeping the LCA’s as close to level as possible. Drawing a picture with the LCA’s inclined down, level, and up, along with some imagination, is the best way to visualize rollsteer.
