LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Suspension & Brakes (https://ls1tech.com/forums/suspension-brakes-16/)
-   -   PHB & LCA's: Single Adjustable or Double? (https://ls1tech.com/forums/suspension-brakes/381600-phb-lcas-single-adjustable-double.html)
shudog Sep 17, 2005 08:50 AM
Probably going with UMI products with the rod-ends.
What is the advantage of the double adjustable over the single?
felton316 Sep 17, 2005 09:27 PM
Double Adjustable-- You can loosen the jam nuts and adjust it while on the car.
Single Adjustable-- You must remove one end from the car to adjust it.
BADZ Sep 18, 2005 07:11 PM
Correct!!!!
shudog Sep 19, 2005 12:57 PM
Excellent! That's all I needed. Thanks
© 2026 MH Sub I, LLC dba Internet Brands
