6 Pt. Roll Cage?
6 Pt. Roll Cage?
Well it has come time to break down and cage my ride because I keep getting told I can't run past the 1/8th. I just have a few questions for you guys that went with a 6 pt.cage.
I am most likely gonna get a Wolfe 6 pt. 4130 Chrome Moly cage with swingouts, over the rear seat, and low side bars. Should I get it jig notched? Also what complications if any did you notice from/after the install? Is there anything that I need watch for.?. I know that chrome moly stuff has to be TIG welded. What is the wieght difference between the regular steel and Chrome moly? Any help would be greatly appreciated!
Originally Posted by SS2win
I would go mild steel (DOM not HREW) due to the fact that 4130 is difficult to weld properly.
My ride has a custom chrome moly 6pt cage with swing doors. Found a local fabrication shop that does excellent work and had them do it.
Originally Posted by Inspector12
LETHL_SS- I would like to see some better pictures of your cage as I can't see much in the one you posted thanks.
