Vibrate or clunking when turning the wheels
I just noticed that when I turn the wheel to the left I get a slight vibration or a clunking thru the streering wheel only when turned.It drives a straight line and does not pull or grab when you stop.Anyone know what it could be ? Thanks in advance.The car only has 23,000 miles.
Originally Posted by Josh
I'd like to see some thoughts on this issue, as well. Since installing a 12-bolt, I get a clunking from the rear when making a semi-sharp left turn.
Josh
Josh
Originally Posted by stang killer
make sure all your lugs are tight.
I had the same thing happen to me and one day when I was driving *BAM* the back wheel falls off Luckily I wasnt driving very fast and the wheel stayed in the wheel well.
also check your steering rack for any damage.
