For those who want to see ride height after springs
Old 05-02-2006, 06:44 PM
  #61
Camaro Rick's Avatar
Could someone direct me toward a tutorial on this "Hose mod" or should I just do a search..hah.
Old 05-02-2006, 10:31 PM
  #62
Italiano99's Avatar
Originally Posted by Marc '99T/A
You could do just the rear hose mod, but I think that's about it.
will that lower the entire car, and how much?
Old 05-02-2006, 10:49 PM
  #63
Marc '99T/A's Avatar
Take out the rear springs; they sit in a rubber piece up top. get some 5/8" heater hose. Cut a slit along the length of the hose, and wrap around the top coil of the rear springs. Re-install the springs (without the rubber piece). It is a very easy mod. The most difficult part is jacking the car up....honestly.
Italiano - I think it will lower the rear of the car about 1/2", but obviously the front of the car isn't dropped any.
Old 05-03-2006, 11:46 AM
  #64
J. Brown's Avatar
I didn't cut a slit.............just slipped it over the top coil.
Old 05-03-2006, 07:51 PM
  #65
skewba98z28's Avatar
Plus one. Hell Ray Charles could do the mod. It just lowers the rear guys.
Old 05-09-2006, 12:37 AM
  #66
Onyx Z's Avatar
Does anyone happen to know who's red WS6 that is on Sportlines?
Old 05-21-2006, 03:52 PM
  #67
Viper's Avatar
Eibach Pro stance, pretty low in the front. 1 finger at best.
Attached Thumbnails For those who want to see ride height after springs-dscf0003s.jpg   For those who want to see ride height after springs-img_0931s.jpg
Old 05-22-2006, 07:33 PM
  #68
whatbrown's Avatar
Eibach sportlines. It's the perfect combination of looks and practicality in my opinion.
Old 05-23-2006, 01:54 PM
  #69
Italiano99's Avatar
do you guys recomend shocks with those Eibach sportlines? I mean are they required? I plan on them in the future some time but I just want to lower my car for now
Old 05-23-2006, 02:04 PM
  #70
Viper's Avatar
Any lowering spring requires a different shock; the stock decarbons can barely control the stock spring let alone a lowered one.
Old 05-23-2006, 06:45 PM
  #71
Definetly need them with Sportlines if you want to exploit the full capability of them
Old 05-27-2006, 02:41 PM
  #72
TRANSAM_2000's Avatar
Does anyone have pics of a lowered T/A with stock 16 inch chrome rims and if so how much did you lower it
Old 05-28-2006, 10:31 PM
  #73
Zinc's Avatar
Prokit, with QA1 adjustable coilovers (JUST installed prior to this mini-shoot, so I didn't have them adjusted perfectly, but good enough) on stock 16" wheels.
Old 05-28-2006, 10:32 PM
  #74
Zinc's Avatar
Few more QUICK pics from yesterday w/ the new wheels. more high res, nicer pics soon..
Old 06-05-2006, 10:51 PM
  #75
VinR1's Avatar
bump for a helpful thread
dumb question - if someone used springs meant for an LS1 car in an LT1, would the heavier engine weight the front of the car down slightly lower?
Old 06-08-2006, 11:55 AM
  #76
Yep sure will.
Old 06-28-2006, 06:27 PM
  #77
NufNuffZ28's Avatar
I have Hypercoil Springs if you want to add these pics to your database. Advertised at 1.25'' drop, but it is def. more!
Old 07-09-2006, 11:13 AM
  #78
jblindy's Avatar
Granatelli lowering springs with stock struts and shocks. I wish that I woulda changed the shocks and struts as well. The ride is horrible but the look is good. I'm considering getting the QA1 Generation F Coil-Over for the front and the QA1 Generation F shocks for the rear. Anybody have these?
Old 07-12-2006, 11:53 AM
  #79
MOE_TAWS6's Avatar
Goldline springs...(So far i only dropped the back, ill post pics when i put the front ones on too) And no, i dont drive it like that...its sitting at the shop. lol
Old 07-13-2006, 10:12 PM
  #80
UsaTraveler's Avatar
Here's mine. Pic and info in sig. With this much of a drop the adjustable torque arm and panhard rod are a must. Without them the pinion angle and side-to-side location of the rearend will be out of whack. I haven't done the shocks yet. It rides firm, but not obnoxious.
Quick Reply: For those who want to see ride height after springs
