BMR LCA Question
BMR LCA Question
My LCA's (poly/rubber) only have 1 grease fitting on each. I wouldn't have thought twice about this but one has the zerk fitting in the poly end and the other has it in the rubber end. It can't be right, has anyone else seen this? Do I just need to get two more zerk fittings for the other ends or should they just be in the one end If so which end?
Thanks, Chris
Thanks, Chris
LS1Tech Premium Sponsor
You don't grease the rubber bushings that's why there is no grease fitting
Lee Spicher
lee@bmrfabrication.com
(813) 986-9302
Lee Spicher
(813) 986-9302
Yes, that's correct both ends are tapped for the zerk fitting...
Lee Spicher
(813)986-9302
Lee Spicher
(813)986-9302
