Your favorite Steering Wheel (with Air Bag)?
Hey folks,
Of all the (air bag equipped) cars you've owned, which one had your favorite steering wheel for performance driving?
I've heard from many sources that, for best control, you should hold the wheel at 3 and 9 oclock. My favorite wheel (but sans air bag) was from an '86 Vette; it had a thick rim, and spokes at 4 and 8 oclock, allowing me to grip the wheel at 3 and 9 oclock. My current car ('02 Bird) has a thin wheel and spokes at 3, 5, 7 and 9 oclock; blocking me from placing my hands where they want to be. I want to have an airbag, so swapping an aftermarket wheel, or '86 Vette wheel, into the car is out of the question. From pictures, the '93-99 Camaro wheel or '94-96 Vette wheel looks like it should do the trick, but I have no experience with them. What are your thoughts?
Keith
Keith
my 99 grand am gt had a sweet steering wheel in it, was thick and had like a scuffed leather on it so it never slipped in my hands, kinda dont like the thin one in my 01 trans am and its real smooth and a lil slippery like at times, but now that i think about it, it would look gawdy with a thicker steering wheel in my ta IMO
My 2002 Silverado has the best airbag steering wheel I've ever seen. The airbag must be more compact on this one.
However, I suggest you get rid of the airbag and install a Momo wheel and a five point harness. If you put your hands at 3 and 9, the airbag will break your arms when it goes off. Not to mention you can't see where to steer with the deployed airbag in your face.
Now, about that 'break your arms when it goes off"? I've never experienced an air bag deployment. Do arms really get broken when bags deploy? Do car makers put spokes on the steering wheel to prevent hands from holding where arms would be broken? Maybe that's why any air-bag wheel I've ever held sucks! I could see where broken arms would be better than getting thrown through the windshield or biting the steering wheel in half. But if you wear the proper restraint to begin with, none of that would happen. I wish car makers would design restraint systems for people who appreciate their value, rather than designing passive stuff for people who can't be bothered.
Originally Posted by KeithB
I'll have to look at the '02 Silverado wheel, but you give me some great food for thought about a non-airbag wheel plus five point harness; thanks! Do you need a roll bar to anchor a five-point?
Originally Posted by dailydriver
Cal, do you think I would be able to use this arguement if I'm ever caught in a spot check, or if my state inspection wises up to no airbag wheels?? I hope so, 'cause they will not get my Sparco suede wheel until they pry it out of my cold, dead hands!!!!!!!!!!!!!!!!!! I will give up the car before I go back to that stock, plastic P.O.S. just to have a damned airbag!!
The '02 Silverado wheel has a small enough air bag so it still has spokes; nice leather wheel too.
There have been some people with broken arms from airbag deployment; the air bag is deployed very rapidly, almost explosively, with rocket engine propellant. Now some driver's ed instructors teach kids to hold the wheel at 5 and 7 O'clock and slide the seat as far back as possible because of this. Of course that isn't a very efficient way to steer the car.
Stock seat belts are almost worthless anyway with only one shoulder strap, narrow webbing, and no anti-submarine strap. In a roll over in the wrong direction, you just fall out of the single shoulder strap (it only restrains you in one direction.) Ask me how I found that out! In a front end impact, you can slide right under the lap belt. And in a hit from any direction, the skinny stock belts will stretch like rubber bands and let your body hit things. Harness belts are much wider. No wonder we have air bags! But a airbag is like fixing the symtoms of the problem rather than correcting the problem itself.
Air bags will not break your arms, at least they didn't mine when my hands where on the steering wheel at 3 and 9. This is personal experience not I have read/heard. The air bag hit my lips and it stinged that was all yes they do propel fast but it will not brake your arms unless you have weak bones.
Holly thread hijack Batman!!
Yes, it is possible to break your arms if you consider your wrist your arm. This is fairly unlikely though and not something to worry about. Keep your hands at 3 and 9 so that you have better control and can avoid the collision in the first place.
This is like saying you should wear ankle supports because in a frontal collision some people will break thier ankles now. This is actually more common than the wrist/arm breakage...
Anyway, back on topic, does this have to be a GM to fit properly or are most steering wheels interchangeable? If any is an option, there's alot of options then...
The spline patterns on most steering wheels are not interchangeable. However, the older fbody patterns do fit 4th gens. The incompatiblitly comes in with different spacings between the steering wheel hub and column. You can compensate for that by using a custom bezel or collar under the wheel. I just used the one that came with a Grant wheel and cut it back about 3/16" on my lathe. You could also use a grinder and a file to do this. A lot of companies like Grant won't sell you a steering wheel adapter for a car that came with a airbag, so this is a way you can work around that. I used the Grant adapter for a '75 Camaro.
I used the ol' standard Momo 2401 (? I believe) and turned down the back of it to fit the column without rubbing.
http://www.thunderracing.com/catalog...gories&pcid=78
It's not hard to do yourself though if you have access to a lathe.
Looks like Thunder Racing sells the 2401 adapter already turned down for a 4th gen:
I guess we're not the only ones who despise the ugly, thin, uncomfortable, plastic stocker!!!
As for on-wheel radio controls, I liked that when I actually had a radio in the car! A monsoon stereo system with all components adds up to about 40 lbs.
