Cheap Shocks any Good?
Getting ready to install a set of lowering springs(1.5in). My car has 60K miles and at this point do not have enough money to buy a good set of shocks. My question is are cheapo shocks from autozone/oriellys worth getting for the interum. Will the cheapo shocks be an improvement over originals with 60K. What do you guys think. TIA
No. I bought KYB GasAJust shocks and installed them with my Hotchkis springs. They were far too soft. I thought it was OK, but the more I drove it, the more I realized the shocks weren't up to the task. I know it's easy to say and hard to do, but if you can save your money and buy good shocks (i.e. Koni SA or revalved Bilsteins from Sam Strano), you will be much happier and you won't have to swap your shocks twice.
-Mike
-Mike
Moderator
I have been pretty happy with the Gabriel Hi-Jackers I
put in the rear, it never felt "squirrely" or wheel-hopped
or anything. Hotchkiss and now stockers minus the donuts
out back.
I'm very interested in some of the cheap-bastard shock
alternatives (various heavy duty types, suspicious of
any like the "Sens-A-Trac" where ride height modifies
the damping rate, in a lowered application though).
Haven't seen any quantitative info on damping rates
other than for Bilsteins and stockers. I wonder whether
that kind of info could be had from the makers' tech
line or something....
out back.
Let's face it, any and I mean any damper will be an improvement over the decarbons. Although not ideal some have used Bilstein HD's, having Sam Strano revalve them will make a HUGE difference. I agree with Mike, and save for good shocks. They are the single best improvement you could do to your suspension IMO.
I agree with those who are adamantly against using cheap and/or poorly designed dampers. Dampers (not really shock absorbers, though that's a popular term in N. America) are absolutely crucial to dampen spring oscillation, and in a correct manner that I might add.
My friend thinks that his TA with stock springs and KYB adjustable shocks are good. He doesn't know any different tho. He wants to lower it. I told him that I don't think those shocks work well with lowering springs. He just won't believe me. On the other hand...my prokit and revalves are freakin' sweet!
protraxduner, I did exactly what you did. I went and bought some cheapo's from Advance Auto and put them on the car in order to save up for different shocks. Didn't make it a week then I bought Koni's for the front. It was horrid. Just save up for better shocks...
Originally Posted by FIREHAWK#608
OneMeanZ- how do you like the Koni's?
LS1TECH Sponsor
I'm interested in dampening on the rebound as well. Thanks
Cheap shocks are well.... cheap. Like anything in life you will find folks that can't afford more, don't want to pay more, or don't know why they should. I wear New Balance sneakers for example, not Wal-Mart's. Would the cheapies fit? Probably.... Would I be barefoot? No. But they certainly won't last as long or feel as good either.
Which leads me to this point. Money tends to buy better product, but not always is the product what YOU need. To continue me shoe analogy. Nike's are not cheap, but they don't fit me well and I tend to tear them up quickly.
Auto parts are the same. Too many folks view stuff as "parts is parts" and that no more the case than food is food, or shoes are shoes.
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
