sway bar bolts
sway bar bolts
i just did a 9" swap, and I snaped the loooooooooooooong *** bolts at the end of my stock sway bar
i'm ordering the BMR 32mm sway bar, and am expecting some hard launches
do i use the same set up? if so, what bolt size do i need?
or does the BMR kit come with something more beefy?
Those are the endlinks. You can get those pretty cheap at most auto parts stores, or you could spring for the Energy Suspension urethane endlinks, though their benefits are debatable.
If you're getting a 32mm rear sway bar, you will be the new king of understeer.
-Mike
-Mike
