What are the "must-have" suspension parts?
#62
Originally Posted by Foxxton
I'm assuming from what you typed Ace that everything on your vehicle is stock right now, including shocks. If you are riding on stock decarbons, then you ought to look into new shocks, and since you are considering AX, you should consider Koni SA's. Not trying to upsell you, however it's a good shocks for daily driver, AX, and some drag racing. Stock Decarbons have really poor valving to begin with.
Your panhard rod may not be as off as some others, however once you lower, then you'll really know if the "tolerance lottery" has got the best of your PHB or not. You can't lose by buying a PHB this early in the upgrade game, however it doesn't quite yield an effective difference for what it does. It's a necessary part, but just doesn't have as great of a "feel" of improvement as shocks and/or swaybars have.
My 2 cents would be just to keep saving money and perform more research on the parts for improving handling. The sticky is pretty much spot on. If you really want to get a good perception of how well your vehicle handles on the stock suspension (or how horrible it does), try to find an AX club somewhere and possibly a licenced instructor with good experience.
Yes everything is stock and, it's in good health atleast
I just wondered if some of these parts will help before need to replace shocks comes up or if saving up and waiting is a wiser idea.
I think I know what i'm going to do now
#63
Originally Posted by JEB99TA
Sub-frames are what a lot of the most experienced guys have said on this board. When asking what causes body wrinkles from flex, most will first and foremost tell you sub-frame connectors.
#64
[QUOTE]
12-17-2005, 06:06 PM #12 davered00ss vbmenu_register("postmenu_3947361", true);
Trader Rating: (2)
Weld in's & SFC's should be your first mod.
__________________
2000 SS M6, Kooks Headers w/Magnaflow cats & y-pipe, Magnaflow Cat-Back, SLP Lid, TSP proted TB, LS6 Intake, Spec 3F w/ billet flywheel, 4.10's, UMI DS Loop, panhard rod, LCA's, BMR STB, Tubular SFC's, TR 224, Comp 918's, Titainium Retainers, Double roller timming chain, LS1 Edit by Slowhawk
12-22-2005, 02:23 PM #50 jam01 vbmenu_register("postmenu_3970476", true);
Trader Rating: (0)
ive owned 10 camaros a 67,68,72,75,77,two 83"s 84 t/a, 89 convertible and my 02. i bought each of theses cars used. from my experience so far from the older models they would have benefited from having sfc's. my 02 is the only one ive put them on so far, i still own one of the 83's 84 t/a and the convertible.ive had body work done to the 83 to repair the stress cracks from twisting, and im not taking a chance with my 02. ill give you evolution on the camaro has improved from each model but facts are there just not a full frame car. even they twist, witch is why i bought the 3 point. i should have bought weld in's but my area lacks decent welders with lifts, plus the fact i like working on my own vehicles. my testing has been going on for 23 yrs plus. ive also owned other chevys too, but the last 10yrs or so have been camaros.
12-28-2005, 11:46 AM #71 GR33N GoblinM6 vbmenu_register("postmenu_3994801", true);
Trader Rating: (3)
i think its funny that Foxxton and his B.S. degree, doesnt think a STB is needed but the PHd's and Masters of the GM engineers put a STB on GTO's..
if you look at other auto manufacturers .. they do this also.. so im going to trust the acutal manufacturers of vehicles, people that are highly funded, years of experience, and do this on a daily basis..
__________________
98 Z28 M6
12-28-2005, 02:41 PM #72 BULLET99Z28 vbmenu_register("postmenu_3995637", true);
Trader Rating: (3)
Get welded in if u can. I have Boxed BMR's, and I could tell a difference as soon as I left the shop. The car planted better under power, handled better,handled larger bumps better(car stayed more rigid)I could tell the ar wasn't flexing as much. Chassis rigidity is very important so the suspension can do its job. I can feel the difference in how much tighter the car is.Also, I can put a jack just in front of the left rear tire, and the right rear will come off the ground also, the car is more rigid period, I would recoment SFC's to anyone. And Foxxton- the car only had 30k,older 1owner,mint condition, and it had new bilsteins- So even on a nice,not abused,w/ good shocks, the SFC's did make a differnce in how stiffer the car felt. One more point mr Foxxton- I raced sprint cars for 9 years, I know a little bit about how a car "feels" , I know what chassis flex feels like, and I could feel the extra rigidity in my car after SFC's
__________________
I hate mustangs,99z28m6, hookerLT's,DrGas Xpipe trueduals,ShanerS3,K&Nw/lid/ram air mod,160tsat,BMR subframe/strutbrace,she pretty
12-28-2005, 09:05 PM #76 BJM vbmenu_register("postmenu_3997543", true);
Trader Rating: (0)
Let's keep our eye on the real ball. There are two camps, the "STB and SFCs are needed club" and the "STB and SFCs are useless club". Both are right for different reasons and I have not seen anyone really distinguish between the following points.
It would take a great deal of flexibility in a car for a brace to much increase a car's handling. If an autocrosser added a brace and suddenly improved their standings then that car really needed help. So I agree the "useless" club is right, from that particular pespective.
However, again, people are just not adding them for that reason. They add them to improve NVH. Just a look at the comments in the 20 or more SFC threads. people say things like, "I noticed as soon as I got the car back", or "The car feels more solid", " Most of my squeaks and rattles are gone". The situations described are just normal street driving. The added stiffness in the car's most flexible areas helps this out and its quite apparent why. So the "needed" camp is right as well. To my G-body Buick GN I added rear seat bracing, engine cross member braces, fender to rad support braces, each subtley improved the car's feel, but overall on a road race track I used to drive it on I noticed no overall performance improvement other than a more solid feel.
Can't we agree to at least disagree?
12-29-2005, 04:47 AM #79 BULLET99Z28 vbmenu_register("postmenu_3999061", true);
Trader Rating: (3)
I read the whoel thread, no disrespect, but I could tell that sfc's tightened the car up, it was worth my money.
__________________
01-14-2006, 05:24 AM #101 0rion vbmenu_register("postmenu_4081113", true);
Trader Rating: (0)
I can't speak for anyone else but I had weld in UMI's put in and noticed a difference immediately. Much more solid. My car used to creak pulling into the driveway but stopped the same day I put the SFC's in. I highly recommend them regardless of what the experts say. Would you believe 3 people or 300?
__________________
98 formula with stuff done to it
02-01-2006, 12:45 PM #116 Radcat vbmenu_register("postmenu_4182361", true);
Trader Rating: (1)
Just had some BMR weld ins put in last night. Car feels so much better. It doesn't feel like a boat when I take a corner and it feels like I have more control over bumps. The car doesn't squeak anymore either!
__________________
2000 Firebird
turbo 3.8 349hp 415tq RIP
02 LS1 swap K&N, LT and 4.10s
I bought my BMR SFCs for like 100 bucks and welded them in myself, one of the best bang for the buck mods I ever did. Not quite sure why you are anti-SFC
A search will prove you wrong. If you look at some of the experienced AXer's and RRer's they know the real deal behind SFC's. Besides, where are the pics for the wrinkles?
Trader Rating: (2)
__________________
Trader Rating: (0)
Trader Rating: (3)
__________________
98 Z28 M6
Trader Rating: (3)
__________________
Trader Rating: (0)
Trader Rating: (3)
__________________
Trader Rating: (0)
__________________
Trader Rating: (1)
__________________
2000 Firebird
#65
Exactly my point, those haven't road raced with a 4th gen like mitchntx, trackbird, Cal, Sam Strano, and numerous others around.
BTW, still waiting for those wrinkle pics.
Each and every one of those claims are FLAWED! Unless you can perform testing in a fourth gen extensively with the experience that I and the others above have, you'll get those results.
#66
I group of people telling you they are better proves anything how?
Lap times trap speeds etc prove it a few people on the internet who I have no idea how much they know about cars telling me a mod is good will not sell me.
#70
Foxxton ... what major AX/RR races have you won?
#71
BTW, reread this thread from Sam Strano, one who competes in SCCA AX.
https://ls1tech.com/forums/showthrea...3&page=1&pp=10
#72
And from LG himself,
https://ls1tech.com/forums/showthrea...ame+connectors
now you have gotten away from the whole point of SFC's not having their place on a daily driver. If you notice that I praise Ryan @ UMI for realising what SFC's are really used for, and he notices that I only advise to use them for specific purposes, and the same with Sam Strano.
#73
Foxxton > Here's what your pro road racer buddies say about sub-frame connectors.
http://www.hansracecraft.com/testimo...arekpiecyk.htm
Marek Piecyk
2001 Mustang Cobra Coupe
2003 NASA AutoX ESP Champion
Marek Piecyk
#75
AFA an AX champ in an 4th Gen F-body, read this again since you didn't search through the earlier thread:
https://ls1tech.com/forums/showpost....7&postcount=41
#76
#77
Marek Piecyk
Marek Piecyk
#78
I am not twisting words, you are refering to a Fox body mustang AX champ with a company that doesn't make the stuff for any F-body, and not a 4th Gen F-body one, you are also refering as if the intial post dealt with "racing", and you you still haven't posted pics. The post starter asked clearly for a street vehicle.
Now I have some questions for you. Do you know exactly what the appropriate vavlings are usable on a daily driver and with what spring rates? Are you familiar with what the valvings would be good for a daily driver, not a drag racing vehicle? Are you aware of what bar combinations are useful for the vehicle and will not yield snap oversteer through many corners? When you fit your parts, do you do them one at a time or all at once? Are you aware of what happens when you have too much spring rate in the rear when cornering? Do you know why it isn't a good idea to increase more than a 17" wheel diameter for the rear axle?
These are questions that deal directly with what the thread starter wants. Plain and simple. AFA the dimple pics, I would be grateful if anybody who has them will post them on a "street" vehicle with street compound tyres, because I still want to see what they really look like.
#79
Nossir, maybe YOU need to go back and re-read THIS.
Championship testimonies mean nothing in themselves. That one is a good one, but he's driving a Mustang, not a 4th Gen F-body. It's down to it's chassis design.
You are just looking for an argument, and not dealing with the fact that the post starter needs mods that will be useful.
#80
Goin' to go have a life for the rest of the night. I'll pick back up on this with you tomorrow a.m.. Been nice talkin' to ya' my friend. I'll post up the pics tomorrow morning for ya' mate.
Camera flash doesn't show the true damage near as well as daylight (leaves too much room for you to once again indicate I'm a liar), so, I'll take some in daylight and show you the damage which I believe was caused by not having subframe connectors.
I just can't help but believe connecting the front and rear subframes doesn't have a positive effect on body flex on the 4th Gen F-Body... whether it's stock, RR/AX, or pure drag.
