what lb springs to use on hal/strange 90/10's
ok for the strange shocks i have seen 80,100,125,175,225,250,275 and many more
my front is pretty much gutted just the basics motor/rad and deleted the ps,ac,swaybar and abs i stay under 1500 miles a year and only drive it on great days to play around and at the strip
i want a quick "snap up" and settle on launch and believe thats what the lb decides right? i have the adj collors for height and want good ground clearence no lowrider here
any info will help thanks
From what I can gather on the front, if your car is really light, run the 275lb springs, if not run the 300lb ones, as far as the rears, unless you have the aftermarket perches welded up on the upper cup in the rear just run stockers in the back. I am running the 275lb strange hypercoils in the front and stock firebird springs with the isolators removed in the back.
