Clunking noise when braking slowly
If I approach a stop I can hear a clunk noise from what sounds like the middle section of the car as I apply/release the brakes but only if stopping quickly or pumping the brakes. That is, as I'm slowing down, if I pump the brakes, I can replicated the sound. Pump... Clu-Clunk. If I'm slowing very slowly you can't hear anything or will only hear the initial clunk upon application of the brakes - nothing when releasing.
This is the list of things I'll be checking whenever I get the spare time to lift it up:
the poly trans mount
all suspension bushings (the LCAs are getting swapped soon)
strut tower bolts
exhaust mounts
visual of the engine mounts
Anything else?
strut tower bolts
exhaust mounts
Anything else?
