Strut Tower Brace does not fit.
I bought a new strut tower brace for my 2000 formula, but it doesn't fit. I tried it on another f-body and it fits ok. How do I make it fit on mine?
Not easy. Factory tolerances (if not a prior vehicle accident) have got the best of you thus a bar made with little or no tolerances inmanufacturing may or may not fit. I have done the same thing you have in the past with my F-body and others as well. Some fit mine, some fit others that didn't fit mine, some didn't any of them. However I can tell you that it isn't a result of tower flex of any kind, believe it or not.
EDIT: Depending on whether the holes are ovaled (not elliptical) or not, you could attempt to enlarge them slightly to fit, however it still may not be enough.
Moderator
My Hotchkiss was too long the first time I put it in, had to
get the pedestals on but nuts just barely threaded, and
use a Phillips screwdriver as a "pilot" to get the cross-
bolt started through, then dog down the "feet" once that
was all set. Now the car is "settled" to the point that it
is easy in & out.
Jacking under the K-member should make the towers come
apart, slightly.
If you have a single tube, regular sort of brace then maybe
you just need to hog out the holes in the direction of the
required slack, with a rat-tail file.
is easy in & out.
apart, slightly.
Originally Posted by KillerKlown
I am thinking about getting one, is it worth all the trouble? What does it do exactly? I would think it would make the "wandering, darting" problem more stable.
When I had mine installed, it did nothing that my SOTP could feel, and look at what driver is doing what AFA their car, AXer's and RRer's do a lot more cornering more often than DDer's do.
Originally Posted by Icyelle
Update on the strut tower brace. My husband made the holes bigger with a dremmel tool, and that did the trick!!! Strut Tower Brace is on and looks awesome...
