Unibody mounted ta question??
I just installed a spohn unibody mounted torque arm on my 01 ws6 m6 and I was wondering if a alot more road noise and vibration was normal. Also there is alot of banging noise coming from where it mounts to the cross member. Every thing is tight and the pinion is set to -3. Any ideas???
I'd change the pinion angle as already recommended. Also, tighten the front mounting bolt a bit (the one the instructions say to keep loose). That will reduce some of the banging you hear. Other than that, you'll still be a bit noisier than stock due to the nature of the front mounting system.
