LCA angle question. I recently got around to installing my relocation brackets. Well there are 3 different holes the LCA can be put in. My question how do I figure out which one to put the LCA in? For right now ive got it in the center hole, which when the car is on the ground, the LCA sits about level, not angled up & not angled down. Does it need to be in the bottom hole so the LCA will angle towards the ground? |
You want the LCA as level as you can get it, so it sounds about right. |
© 2024 MH Sub I, LLC dba Internet Brands
