am i due for a Torque Arm??
ok, well..im basically stock as far as engine goes...got some nice power, will be adding heads and cam at end of summer....
well...anyways...i just installed headers and am going to go true duals...
i heard that is not plenned for, TD's can get in the way if i ever need to install an aftermarket TA...shoudl i go ahead and add one now...then build the TD's around it?!?!?!
if so, i had my eyes on the UMI TA with the built in drive shaft loop for like $300 something...
any thoughts!?!??!!
THANKS
erik
any thoughts!?!??!!
THANKS
erik
Yea, thats a nice piece! Your talking about the tunnel mounted one right?
Thats the one i want (when the time is right)
This is a good piece because:
takes stress off the tranny cause its tunnel mounted
way stronger
can have DS loop put on
adjustable
powdercoated
urithane greasable bushings
all for about $400 If your going all out on your car, you need this piece.
way stronger
adjustable
powdercoated
yeah **** it...i dont think i need a TA right now....and if if it ever comes down to getting one in...well...ill cut the pipes, instal it, and use some band clamps to put it bacm together or something
thanks
thanks
