Double or Single Adjustable LCAs.
No.
Doubles can be louder and rougher than singles because a double has rod ends on both ends. Singles are typically rod end on one end and rubber or poly on the other end.
But neither will hurt your DD ride, it's all about how much noise you can handle. I have single adjustable and the noise is fine. However noise is subjectable to each person.
What do you mean in the sig by full UMI suspension?
LS1Tech Premium Sponsor
What circumstance is it that requires that you need an adjustable lower at all? The only time I recommend them is for larger tire fitment or if someone has incorrectly installed a set of relocation brackets and need to square up the rearend in the car. Just don't want to see you spend hard earned money on them when it could be spent to updgrade other components
Lee Spicher
lee@bmrfabrication.com
(813)986-9302
Lee Spicher
(813)986-9302
