Just picked up some C5 brakes ($100)!!!!
went to a swap meet today, and scored a set of corvette brakes for $100.
2 front rotors
2 rear rotors
2 front calipers
2 rear calipers
pads and hardware
minus "GM Corvette Caliper Pad Abutment Brackets," for the front and rear (prolly will pick some up from E-Bay)
UMIperformance has "GM F-Body C5 Front Brake Conversion Brackets" $230.00
My questions for you:
anybody carry mounts for the REAR calliper?
is it even worth converting the rears?
also where can i find steel braded lines for all 4 corners?
THANK YOU
2 front rotors
2 rear rotors
2 front calipers
2 rear calipers
pads and hardware
THANK YOU
.....where can i find steel braded lines for all 4 corners?
THANK YOU
THANK YOU
Steve
2 front rotors
2 rear rotors
2 front calipers
2 rear calipers
pads and hardware
THANK YOU
2 front rotors
2 rear rotors
2 front calipers
2 rear calipers
pads and hardware
THANK YOU
Hi there,
Well I would like to say I could help, but we do not have stuff like that. I do however know someone that should be able to help. PM me if you would like the contact info
Friendly regards
Originally Posted by Xsta Z 28
No point in doing the rear calipers/rotors, F-Car and Vettes are virtually identical on the rears.
