Transmission crossmember
What's the difference between the transmission crossmember for the 93-02 A4 and the M6? This is removable correct? Need details on it and can they be removed.
Originally Posted by Honda Hunter
Can the crossmember be modified to look exactly like the M6?
You arnt going to want to try and make the M6 work, the bolt holes have to be real tight fitting so the trans doenst slide bake and forth.
What about using a aftermarket tubular crossmember?
That's a posobility but I dont know if it would help or hurt. I'm trying to install a global west traction link torque arm that was designed for a M6. Heres more details:
http://para.noid.org/98z/traclink.html
"Globalwest has three Tracklink kits for 4th generation F-body cars. They are for 1993 - 2000 cars with manual transmissions, 1993 - 1997 cars with automatic transmissions, and 1998 - 2000 cars with automatic transmissions."
"The difference between these cars are the the beams. The transmission crossmembers are different between these three types of cars."
i need to overcome this difference so I dont get stuck with this TQ arm.
