What's a good shock for the Pro Kit??
when i lowered my 02 z28, i went with the pro kit and koni single adjustables. i dont really wanna spend 700 on shocks again. my ss is a street car so i just want a shock that will match up good with the pro kit and handle the drop well. how are the hd bilsteins? any other suggestions?
LS1TECH Sponsor
Originally Posted by Hobb3s
I was in the same boat and went with a set of re-valved bilsteins. However they are pretty danged slow in getting them to me.
Would you prefer a generic setup that's "good enough"?
Revalves take time to be worked for you. We try very hard to make sure folks know it's running about 3 weeks currently for Revalves to be done.
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
LS1TECH Sponsor
__________________
Originally Posted by Sam Strano
HD's are not for lowered springs. You want to try, that's fine, but you won't like it nearly as much since you've had Koni's. Which is why we do the Revalves. Less costly than Koni's, but upgraded damping from HD's.
LS1TECH Sponsor
Well to tell ya the truth I would be hella happy if I had them in three weeks. It's been over a month now and still no word on them
Feel free to call. I don't know your name or anything that would allow me to look.
__________________
I was running koni SA's up front with bilstine HD's out back. The car felt great. It was a little rough but i also had the pro kit so my car was pretty low. Give Sam a call, i did. He will take care of you. He knows his stuff!
You just can't go wrong with Koni here, or Bilsteins that are revalved. Yes they are proportionately more expensive, however the cost to performance ratio is also valid. I went with Konis for the front and rear (more than a step up from revalved Bilsteins) because I knew I wasn't going to be replacing shocks anytime in the future, as well as their handling prowess (they work with coilovers with an adapter in front, and spring perches with an adapter for the rear) for potential race-readyiness since I wanted to buy shocks and struts just once.
